Once you add the event to your calendar app, you'll be able to access the Twitch & YouTube links directly from the calendar appointment.
Topics discussed
Here's what we'll be covering:
- Using n8n-nodes-starter project to build nodes
- Different types of node integrations
- When to choose a node building style: declarative or programmatic?
- Publishing community node npm packages
- Building docker images and installing private nodes
Knowledge level
This webinar will contain quite advanced technical content, so it is highly recommended that you're familiar with node.js and Typescript development.
The speaker
Marcus is a Partner Engineer at n8n responsible for:
● Helping companies to embed / whitelabel n8n
● Community support and n8n experts guidance
● Node Integration Development
Here's a few words from Marcus:
