Reverse engineer short-form videos from Instagram and TikTok using Gemini AI
Who's it for
Content creators, AI video enthusiasts, and digital marketers who want to analyze successful short-form videos and understand their production techniques. Perfect for anyone looking to reverse-engineer viral content or create detailed prompts for AI video generation tools like Google Veo or Sora.
This automation takes any Instagram Reel or TikTok URL and performs a forensic analysis of the video content. The workflow downloads the video, converts it to base64, and uses Google's Gemini 2.5 Pro vision API to generate an extremely detailed "Generative Manifest" - a comprehensive prompt that could be used to recreate the video with AI tools.
The analysis includes:
- Visual medium identification (film stock, camera sensor, lens characteristics)
- Color grading and lighting breakdown
- Shot-by-shot deconstruction with precise timing
- Camera movement and framing details
- Subject description and action choreography
- Environmental and atmospheric details
How to set up
Configure API credentials:
- Add your Apify API key for video scraping
- Set up Google Gemini API authentication
Set up Slack integration (optional):
- Configure Slack OAuth for result sharing
- Update the channel ID where results should be posted
Access the form:
- The workflow creates a web form where you can input video URLs
- Form accepts both Instagram Reel and TikTok URLs
Requirements
- Apify account with API access for video scraping
- Google Cloud account with Gemini API enabled
- Slack workspace (optional, for sharing results)
- Videos must be publicly accessible (no private accounts)
How to customize the workflow
- Modify the analysis prompt: Edit the "set_base_prompt" node to adjust the depth and focus of the video analysis
- Add different platforms: Extend the switch node to handle other video platforms
- Integrate with other tools: Replace Slack with email, Discord, or other notification systems
