Published 2 months ago
This workflow enables a Telegram bot that can:
This allows users to communicate across language barriers by simply speaking to the bot, which will handle the translation seamlessly.
In the translation step the workflow converts the user's speech input to text and detects the language of the input text.
If it's English, it will translate to French. If it's French, it will translate to English.
To change the default translation languages, you can update the prompt in the AI node.
In the output step, we provide the translated text output back to the user and speech output is generated in the translated language.
Update the Settings node to customize the desired languages
Activate the flow
All supported languages:
Implement complex processes faster with n8n
