Auto-post GitHub code summaries to LinkedIn using Gemini AI
Created by: karnVen || ven
karnVen
Last update 4 months ago
Categories
  • Listens for a GitHub push event via Webhook
  • Lists and fetches all files from the pushed repository
  • Decodes base64 file content and merges it into a single text block
  • AI Agent (Gemini 2.5 Flash) analyzes the code and generates a article
  • A second AI Agent converts the article into a LinkedIn-ready post (max 2500 chars)
  • Automatically publishes the post to your LinkedIn profile
Set up steps
  • Connect your GitHub account and configure the Webhook in your repo's settings
  • Add your Google Gemini API key under credentials
  • Connect your LinkedIn OAuth2 account
  • Activate the workflow — posts will publish automatically on every push
