Quick overview
This workflow runs daily to scrape 1688.com wholesale listings with the UnitBytes 1688 Scraper on Apify, normalizes key fields from the results, and exports the extracted items to a CSV file for easy import into tools like Google Sheets or Airtable.
- Runs every 24 hours on a schedule.
- Sets the Apify API token and the actor input (search queries, max items, detail level, and proxy settings).
- Calls the UnitBytes 1688 Scraper actor on Apify via its run-sync endpoint to fetch scraped dataset items as JSON.
- Normalizes each returned record into a flat set of fields (such as id, offerId, url, title, page, and position).
- Converts the normalized results into a CSV file named
1688-scraper-dataset-export.csv.
- Create an Apify account, get your Apify API token, and replace
YOUR_APIFY_API_TOKEN in the input step.
- Update the actor input parameters (for example
queries, maxItems, detailLevel, and proxyConfiguration) to match what you want to scrape.
- If you want the results in Google Sheets, Airtable, or another destination, add the corresponding n8n node after the CSV export and configure its credentials and target resource.
Requirements
