Quick overview
This workflow uses n8n Data Tables and Google Gemini embeddings to map product listings to the best matching marketplace category, automatically applying high-confidence matches and routing uncertain results to a human review queue.
- Manually runs a one-time setup that creates two n8n Data Tables and inserts demo categories and products.
- Manually runs an indexing step that reads all category paths, generates Google Gemini embeddings, and stores them in an in-memory vector store.
- Manually starts the mapping step that loads pending products from the products Data Table and processes them one at a time.
- For each product, generates a Google Gemini embedding and retrieves a shortlist of the most similar categories from the in-memory vector store.
- Uses the Google Gemini chat model to pick a single category_id (or NONE) from the shortlist and returns a structured reason.
- Validates the pick against the shortlist and a similarity threshold, then updates the product row as either mapped (with category details) or needs_review (with candidates and review reason).
- Create a Google Gemini (PaLM) API credential and select it for both Gemini embedding nodes and the Gemini chat model node.
- Run “Run once: create tables and demo data”, then replace the demo rows by importing your own category tree and products into the marketplace_categories and products_to_map Data Tables.
- Run “Step 1: index the category tree” after any n8n restart or category-tree change, since the in-memory vector store is cleared on restart.
- Review and adjust the shortlist size and minimum similarity threshold (shortlist_size and min_top_score) to control auto-mapping versus the needs_review queue.
Requirements
- n8n with Data Tables (tested on n8n 2.44.5) and a Google Gemini API key; the free tier is enough to try it.
Customization
- min_top_score (0.62) is only a starting point: run 20-30 products, compare top_score of right and wrong picks and set the threshold between them. The in-memory store is cleared on restart, so re-run Step 1 or swap it for Qdrant, Supabase or PGVector.
Additional info
Tested end to end on the demo data with a real Gemini key: the cordless drill and the cast iron skillet were mapped to the right leaf categories, and the karaoke microphone (no fitting category in the demo tree) went to needs_review instead of getting a wrong category. The model never decides alone: a Code node checks that the picked id is in the shortlist and that the best similarity clears the threshold.
