Quick overview
Prepare PDFs for RAG with a low-code workflow that extracts Markdown, applies OCR when needed, and creates page-referenced text chunks. Resume processing from checkpoints, review flagged pages, and download the results before indexing in your chosen system.
- Receives a PDF (and optional prior checkpoint.json), OCR strategy, and optional page exclusions through an n8n form.
- Validates file size/type, exclusion input, and (if provided) verifies the checkpoint matches the same PDF and extraction settings.
- Uses pdfRest PDF Info to read the PDF page count and confirm the document is not password-protected.
- Selects up to a configured batch of unprocessed pages (reusing READY pages from the checkpoint and skipping excluded pages) and processes them one page at a time.
- Reads each page as Markdown and checks for sparse or damaged text. Auto mode applies OCR when needed; Force mode applies OCR to every selected page before extracting Markdown.
- Builds a review package with page-referenced source.md, chunks.json (only READY pages, chunked within each page), manifest.json, and an updated checkpoint.json, then compresses everything into a ZIP for download.
- Stops with an error after delivering the ZIP if any page failed processing, or returns a status like READY/NEEDS_REVIEW/PARTIAL to guide the next resume run.
- Install the @pdfrest/n8n-nodes-pdfrest community node package, or update your existing installation to the latest available version.
- Create a pdfRest API credential using your pdfRest Pro API key, then select it on all five pdfRest nodes. Ensure the API base URL matches the environment associated with your key.
- Review and adjust the processing limits and chunk settings (pages per run, max PDF size/pages, OCR languages, chunk size/overlap) in the workflow’s settings code.
- Start by submitting a small test PDF via the form, then download and inspect the ZIP outputs (README.txt, source.md, chunks.json, manifest.json, checkpoint.json) before running on real documents.
- To continue processing a large PDF across multiple runs, resubmit the exact same PDF along with the previously generated checkpoint.json and keep the same OCR strategy and extraction settings.
Requirements
- A pdfRest Pro account and API key with OCR and Markdown access and unredacted output.
- The @pdfrest/n8n-nodes-pdfrest community node package installed in n8n.
- PDF file and page limits are configurable in the Settings node. PDFs requiring an opening password must be unlocked before upload; this template does not include a decryption step.
- For self-hosted n8n, access to the built-in crypto module in Code nodes.
Customization
- Adjust pages per batch, file-size limits, and text thresholds in the Settings node.
- Choose OCR languages and Auto or Force OCR.
- Adjust chunk size and overlap while retaining original page references.
- Connect reviewed READY output to your preferred indexing workflow.
- Configure a separate error workflow for production failure notifications.
Additional info
READY means automated text checks passed; it does not guarantee complete or accurate extraction. Review text before indexing. Blank or sparse pages remain flagged unless explicitly excluded with a reason. This template prepares downloadable files only; no vector database, embedding service, or indexing credentials are required. Checkpoints are saved in completed ZIP packages, not continuously during processing.
