Detect WooCommerce order fraud and send alerts to Slack
WooCommerce Fraud Detection & Slack Alert Workflow
This workflow automatically monitors WooCommerce orders, evaluates them for fraud using multiple checks (address mismatch, high-value orders, suspicious emails, admin orders), calculates a fraud score and sends alerts to Slack when risk is detected.
Quick Implementation Steps
  1. Import the workflow JSON into n8n
  2. Configure WooCommerce API credentials
  3. Set up Slack API credentials and channel
  4. Adjust fraud rules (amount threshold, email regex, etc.)
  5. Test with sample order data
  6. Activate the workflow
What It Does
This workflow automates fraud detection for WooCommerce orders by applying multiple validation checks and assigning a fraud score. It starts with scheduled execution, fetches order data and prepares it for evaluation by extracting key details such as billing information, order value and customer email.
Once the data is prepared, the workflow applies a series of fraud detection rules. These include checking whether billing and shipping details mismatch, identifying high-value orders, detecting suspicious or disposable email addresses and verifying if the order was created by an admin. Each condition contributes to a fraud score based on predefined logic.
Finally, all signals are merged and a fraud score is calculated. If the score crosses the defined threshold, a detailed alert is sent to a Slack channel with complete order and risk information, enabling quick manual review and action.
Who’s It For
  • eCommerce store owners using WooCommerce
  • Fraud prevention and risk management teams
  • Operations teams handling order validation
  • Developers building automation workflows in n8n
  • Businesses wanting real-time fraud alerts in Slack
Requirements to Use This Workflow
  • n8n instance (self-hosted or cloud)
  • WooCommerce store with API access enabled
  • WooCommerce API credentials configured in n8n
  • Slack workspace with API credentials
  • Slack channel ID for sending alerts
  • Basic understanding of n8n nodes and workflows
How It Works & Set Up
Setup Instructions
  1. Import the workflow JSON into your n8n workspace
  2. Configure the Schedule Trigger node to define execution frequency
  3. Set up the WooCommerce node:
    • Add API credentials
    • Ensure correct store URL
    • Modify orderId if needed
  4. Configure Slack node:
    • Connect Slack API credentials
    • Select or update the target channel
  5. Review Set nodes:
    • Ensure fields like email, total and address are correctly mapped
  6. Validate IF conditions:
    • Status check (pending/processing)
    • Address mismatch logic
    • High-value threshold (default: 500)
    • Email regex for disposable domains
  7. Review Code node logic:
    • Fraud score calculation rules
    • Adjust scoring weights if needed
  8. Test the workflow:
    • Use sample order data
    • Verify Slack alert output
  9. Activate the workflow for automatic execution
How To Customize Nodes
  • Check High Value (>500)
    Modify the threshold value to match your business needs
  • Detect Disposable Email
    Update regex pattern to include more domains
  • Calculate Fraud Score (Code Node)
    Adjust scoring logic:
    if ($json.high_value_order) score += 3;
  • Fraud Threshold Check
    Change minimum score required to trigger alerts
  • Slack Message Node
    Customize alert message format and included fields
Add-ons (Enhancements)
  • Store fraud results in a database (MySQL, MongoDB, etc.)
  • Automatically cancel or hold suspicious orders via WooCommerce API
  • Send email alerts in addition to Slack notifications
  • Add IP geolocation checks for advanced fraud detection
  • Integrate with third-party fraud detection APIs
  • Add risk categorization (Low / Medium / High)
Use Case Examples
  • Detect high-value fraudulent orders before fulfillment
  • Identify mismatched shipping addresses for manual review
  • Flag orders using disposable or temporary email addresses
  • Monitor admin-created orders to reduce internal misuse risk
  • Real-time fraud alerts for operations teams via Slack
There can be many more use cases depending on how you extend and customize this workflow.
Troubleshooting Guide
Issue Possible Cause Solution
No orders fetched Incorrect WooCommerce credentials Verify API keys and store URL
Slack message not sent Wrong Slack credentials or channel ID Reconnect Slack and check channel
Fraud score always 0 Conditions not triggering Verify IF node logic and data mapping
Email detection not working Regex not matching Update regex pattern
Workflow not running Schedule trigger not configured Set interval correctly and activate workflow
Need Help?
If you need assistance setting up this workflow, customizing fraud rules or adding advanced features, our n8n workflow development team at WeblineIndia is here to help.
We can help you:
  • Customize this workflow for your business needs
  • Integrate with external systems and APIs
  • Build advanced fraud detection logic
  • Create fully automated eCommerce workflows
👉 Reach out to WeblineIndia for expert support and tailored automation solutions.
