Create and send Pennylane invoices from webhook data with Slack and Gmail alerts
Who is this for
SMEs and freelancers using Pennylane (the leading French accounting platform) who want to automate invoice creation from their CRM, forms, or any business tool.
What it does
This workflow receives deal or order data via a POST webhook, searches for the customer in Pennylane by email (or creates one if not found), generates a customer invoice with line items and VAT, optionally sends it by email through Pennylane, and notifies your team via Slack and/or Gmail with an HTML-formatted summary.
How to set up
  1. Import this workflow into n8n
  2. Create a Header Auth credential with name Authorization and value Bearer <YOUR_PENNYLANE_TOKEN>
  3. Select your Slack channel in the SL Send Notification node
  4. (Optional) Connect your Gmail credential for HTML email notifications
  5. Configure invoice numbering in your Pennylane settings (required for finalized invoices)
  6. Send a test POST request to the webhook URL with a sample payload
Requirements
  • Pennylane account with API access (Essentiel plan or higher)
  • Pennylane API token with scopes: customer_invoices:all, customers:all
  • (Optional) Slack workspace for team notifications
  • (Optional) Gmail OAuth for email notifications
How to customize
  • Set draft: true in the Code Build Invoice Payload node to create draft invoices for manual review before finalizing
  • Replace Slack/Gmail with Telegram or any other notification channel
  • See example payloads and CRM mappings (Pipedrive, Sellsy, Axonaut) in the GitHub repo: https://github.com/Gauthier-Huguenin/n8n-pennylane-auto-invoicing
