Post top Reddit content to Telegram with GPT-4.1-mini and human approval
Last update 6 months ago
Categories
  • A weekly cron triggers the flow
  • The Reddit node fetches top posts from a +-separated list of subreddits you define
  • A code node normalises each item into {url, title, publishedAt} while preserving Reddit-specific fields like ups, upvote_ratio, and num_comments
  • A deduplication step drops repeats by normalised URL and then by title
  • A scoring step ranks candidates by ups x upvote_ratio and passes the winner plus the top 10 candidates to GPT-4
  • A LangChain agent writes three platform-specific drafts in a single call: a short Telegram blurb with a link
  • Gmail sends you one email containing a draft with APPROVE / DECLINE buttons (sendAndWait, double-confirm)
  • On APPROVE, a Gate node fans out to three parallel branches that post to Telegram, and each result is appended to its own tab in Google Sheets
  • On DECLINE, reviewer feedback is injected into the agent and it picks another topic to retry
Set up steps
  • Setup takes about 15 to 20 minutes
  • Connect a Reddit OAuth2 credential with read access
  • Connect an OpenAI API credential (defaults to gpt-4.1-mini; swap to any model you prefer)
  • Connect a Gmail OAuth2 credential for the approval email and set sendTo to your own address
  • Connect a Telegram Bot API credential and replace @your_telegram_channel in the Post to Telegram node with your real channel handle (your bot must be an admin of the channel)
  • Connect a Google Sheets OAuth2 credential and pick your destination spreadsheet + correct tab in each of the four Google Sheets nodes
  • Edit the default subreddit list inside the Reddit node to match your niche
  • Optional: adjust the GPT prompt inside the Social Posts Generator to match your tone per platform
  • Detailed per-step notes live inside the workflow as sticky notes
