Review GitHub pull requests with GPT-4o and send feedback and Slack alerts
Created by: TakatoYamada || takato-door
TakatoYamada
Last update 2 months ago
Categories
Automatically review pull requests with AI and post feedback as GitHub comments
Who is this for
Engineering teams, code reviewers, and tech leads who want to automate code review feedback. Ideal for repositories with high PR volume where consistent first-pass review is valuable.
What this workflow does
This workflow automates pull request code review using GPT-4o and routes findings to GitHub and Slack. When a pull request is opened, it fetches the raw diff, sends it to GPT-4o for analysis, and posts a formatted Markdown comment with severity rating, categorized issues, suggestions, and an overall score. Critical findings trigger immediate Slack alerts.
How to set up
  1. Add your GitHub OAuth2 credential to the trigger and comment nodes
  2. Add your OpenAI API credential to the GPT-4o node
  3. Add your Slack OAuth2 credential to both Slack notification nodes
  4. Configure n8n Variables: GITHUB_OWNER, GITHUB_REPO, and GITHUB_TOKEN
  5. Activate the workflow - the GitHub webhook registers automatically
  6. Open a test pull request to verify end-to-end execution
Requirements
  • GitHub repository with OAuth2 credentials and Personal Access Token
  • OpenAI API account with GPT-4o access
  • Slack workspace with OAuth2 app installed
  • Two Slack channels: one for critical alerts, one for review summaries
How to customize
Adjust the diff truncation limit (default 12,000 chars) in the Format PR Diff node. Modify the GPT-4o system prompt to focus on specific code quality concerns like security or performance. Update Slack channel routing based on your team's notification policy.
Node List
# Node Name Type Purpose
1 When PR Opened GitHub Trigger Receives pull_request webhook events
2 Check PR Open If Passes only action = opened to avoid duplicates
3 Fetch PR Diff HTTP Request Fetches the raw unified diff from GitHub
4 Format PR Diff Code Extracts PR metadata; truncates diff to 12,000 chars
5 AI Code Review with GPT-4 OpenAI Sends diff to GPT-4o; returns structured JSON review
6 Build Comment for GitHub Code Parses JSON; assembles Markdown comment
7 Post Comment to GitHub GitHub Posts the AI review comment on the pull request
8 Check Critical Severity If Routes based on CRITICAL vs non-critical severity
9 Alert Critical Issues to Slack Slack Sends urgent alert to #incident
10 Share Review Summary on Slack Slack Sends summary notification to #code-reviews
Total: 10 nodes (+ 5 Sticky Notes)
Sticky Note Compliance
# Sticky Note Title Color Role
1 Main Sticky Note (Overview) Yellow Workflow overview, How it works, Setup steps, Customization
2 Trigger and filter PR White Covers GitHub trigger and PR filter
3 Fetch and format diff White Covers diff retrieval and formatting
4 AI review and comment White Covers AI review and comment building
5 Severity check and alerts White Covers severity routing and Slack notifications
All sticky notes use H2 headings (## ) and follow n8n public guidelines.
Tags
ai gpt-4 openai github slack code-review devops automation
