Search Taobao and Tmall products and get the first product detail with JustOneAPI
Quick overview
Automate product search and product details on Taobao and Tmall with structured API data for research, monitoring, reporting, analysis, and downstream n8n workflows.
  1. The workflow starts with configuration for your own JustOneAPI token and search keyword. It calls the relevant Taobao and Tmall endpoint, preserves the raw response for troubleshooting, and converts returned records into a consistent structured format. The normalized output includes identifiers, content or profile fields, timestamps, engagement metadata, pagination information, and source data so it can be reused reliably by storage, dashboards, alerts, reporting, or AI analysis steps.
  1. Import the template and open its configuration node. Enter your own JustOneAPI token, replace the sample search keyword, and review optional pagination, sorting, filtering, and result-limit values. Run the workflow manually with a small test, inspect both the raw response and normalized output, then connect the final records to a spreadsheet, database, dashboard, alert, CRM, archive, or AI workflow according to your use case.
Requirements
  • Your own JustOneAPI token, valid search keyword, and n8n with HTTP Request and Code nodes.
Customization
  • Adjust filters and pagination, process more records, or send output to Google Sheets, Airtable, Notion, Slack, a database, CRM, dashboard, or AI model.
Additional info
Useful for Taobao and Tmall research, monitoring, content intelligence, competitor analysis, and reporting. No platform cookies or browser automation are required; API usage uses the token supplied by the user.
