Enrich and route inbound leads using You.com, Groq, Notion, and Slack
Created by: Kevin Yu || exekyute
Kevin Yu
Last update 4 months ago
Categories
Quick overview
This workflow receives inbound lead details via webhook, enriches the company using You.com search and website content extraction, generates a one-page profile and fit score with Groq, then routes hot leads to Slack, logs all leads to Notion, and returns the enriched result in the webhook response.
  1. Receives a POST webhook request containing a company name and/or domain and normalizes the input into consistent fields.
  2. Rejects the request with a 400 response if neither a company name nor a domain is provided.
  3. Uses You.com Web Search to gather recent company signals (for example funding, news, and leadership changes) and resolves a best-guess company URL.
  4. Uses You.com Content Extraction to pull website content and combines the search signals and site content into a single enrichment context.
  5. Uses Groq (Llama 3.3 70B) to generate a concise one-page company profile and then scores the lead against the defined fit criteria with structured output.
  6. If the fit score meets or exceeds the hot-lead threshold, posts an alert message to a selected Slack channel with an @mention.
  7. Logs the lead, fit score, tier, and profile summary to a Notion database and returns the full enriched profile and score in the webhook response (or a clean 502 error if enrichment fails).
  1. Use a self-hosted n8n instance and install the community node package @youdotcom-oss/n8n-nodes-youdotcom.
  2. Add credentials for You.com, Groq, Slack, and Notion.
  3. Configure the webhook URL in your lead source to send a POST payload containing a company/companyName and/or domain.
  4. Update the fit criteria, hot-score threshold, and Slack mention ID in the configuration step.
  5. Select your Slack channel and connect the Notion node to a database that includes properties for Fit Score (number), Tier (select), and Summary (rich text).
Requirements
  • Self-hosted n8n with the community node @youdotcom-oss/n8n-nodes-youdotcom
  • A You.com API key (you.com/platform)
  • A Groq API key (console.groq.com)
  • A Notion integration and a target database with Fit Score (number), Tier (select), and Summary (rich text)
  • A Slack app with chat:write scope
Customization
  • Edit the scoring prompt and fit criteria to match your ICP
  • Raise or lower the hot-score threshold to control how many leads alert the team
  • Route Warm and Cold tiers to different Slack channels, or skip the alert below a tier
  • Extend the Notion mapping to capture key reasons and recommended action
  • Swap the Groq model on the two model nodes without touching the rest of the flow
Additional info
Self-hosted n8n only, because the You.com integration is a community node. Every external call has an error branch that returns a clean 502 instead of crashing the run.
