Score call audio and alert risky calls with Tyto and Slack
Quick overview
This workflow receives a webhook when a call recording is ready, sends the audio URL to a self-hosted ai-coustics Tyto scoring API, and posts a Slack alert for risky calls before returning the scored JSON response.
  1. Receives a POST webhook containing an audio_url and call_id for a completed call.
  2. Sends the audio URL and call ID to a self-hosted Tyto scoring endpoint via HTTP to retrieve a risk_score, band, and main degradation cause.
  3. Checks whether the returned band indicates a risky call (band equals "bad").
  4. Posts a formatted alert to a selected Slack channel with the call ID, risk score, band, cause, and duration when the call is risky.
  5. Labels non-risky calls as OK.
  6. Returns the resulting JSON payload (including the Tyto scoring fields) as the webhook response for downstream storage or chaining.
  1. Deploy and run a Tyto HTTP wrapper on a machine that has the ai-coustics Tyto SDK and a valid ai-coustics license key.
  2. Update the api_base_url value to point to your Tyto wrapper (for example, http://localhost:8000) and ensure the wrapper exposes a POST /score endpoint.
  3. Add a Slack credential in n8n and select the target channel for the alert message.
  4. Copy the n8n webhook URL (path: /tyto-score) and configure your calling/recording system to POST audio_url and call_id to it.
