Create on-model Shopify product photos with Dreem AI and Slack approvals
Quick overview
This workflow fires when a new Shopify product is created, renders it on a virtual model with Dreem.ai, and appends the shot back to the product - with optional Slack posting and approval.
  1. A Shopify webhook fires when a product is created. Products without a photo are skipped.
  2. The Dreem node renders the product's first image on your chosen virtual model and pose (400+ talents, 700+ poses). A second product image is used as the back reference for accurate back-facing renders.
  3. Dreem renders in the background and calls the workflow back.
  4. Optional: enable the disabled Slack nodes for an Approve / Reject step before anything goes live.
  5. The on-model shot is appended to the Shopify product, keeping existing photos.
  1. Add a Shopify Admin API access token credential with at least read_products and write_products scopes.
  2. Install the Dreem community node and add a Dreem API key credential (dreem_pk_...).
  3. In the Dreem step, set the talentId and shotCodes you want to use and ensure your products include a front image (and optionally a second image for back reference).
  4. (Optional) Add a Slack OAuth2 credential, enable the disabled Slack steps, and select the target Slack channel for posting and approvals.
Requirements
  • Dreem account + API key, Shopify store with Admin API access, Slack (optional, for approvals)
Customization
  • Swap talent and pose on the Generate node, add styling image URLs to control the rest of the outfit, or turn on Slack approval.
