Capture and clean inbound web form leads with an authenticated webhook
Quick overview
This workflow receives inbound web form submissions via an n8n webhook, validates requests using a shared secret header, and cleans and standardizes lead fields (name, email, message, timestamps) so you can reliably pass a structured record into your CRM.
  1. Receives a POST request from your web form via an n8n webhook endpoint.
  2. Validates the request by checking the x-perly-key header against the PERLY_WEBHOOK_SECRET variable and rejects unauthorized traffic.
  3. Normalizes the lead payload by trimming values, lowercasing the email, splitting the full name into first/last name, validating the email format, and adding a received timestamp.
  4. Hands off the cleaned lead record to a placeholder step where you connect your CRM or storage destination.
  1. Set PERLY_WEBHOOK_SECRET as an environment variable (self-hosted) or as an n8n Variable (n8n Cloud).
  2. Copy the webhook URL from the Webhook trigger and configure your form to POST to it with the header x-perly-key: <your secret>.
  3. Replace the placeholder “Connect your CRM here” step with your desired integration (for example HubSpot, Pipedrive, Airtable, or Google Sheets) and map the cleaned fields.
Requirements
  • n8n (Cloud or self-hosted). No external service, API key or AI credits needed.
Customization
  • All cleaning rules live in a single Code node, so you can add fields, change the normalisation or plug in your own validation without touching the rest of the flow.
