Analyze Seoul air pollution with MotherDuck and Ollama Qwen2.5
Quick overview
This workflow exposes a webhook that queries PM10 air pollution data from a MotherDuck database, sends the results to a local Ollama (qwen2.5:3b) model for analysis, and returns an HTML report showing the top polluted Seoul districts and the AI-generated findings.
  1. Receives a request on a webhook endpoint.
  2. Queries MotherDuck via its MCP API to calculate the top 10 Seoul monitoring districts by average PM10, including maximum PM10 values.
  3. Sends the summarized PM10 results to a local Ollama /api/generate endpoint to produce a four-sentence air-quality analysis against the WHO PM10 guideline (50 μg/m³).
  4. Extracts the model’s response text and injects it into a preformatted HTML page.
  5. Returns the HTML report to the webhook caller as the HTTP response.
  1. Create a MotherDuck API bearer token in n8n and ensure the air_pollution database and referenced tables/columns exist for the provided SQL query.
  2. Run Ollama where n8n can reach http://ollama:11434 and pull the qwen2.5:3b model (or update the model name and URL in the request).
  3. Copy the webhook URL from n8n and call the /air-quality endpoint from your browser or monitoring system to render the report.
