Train and run a deep neural network via webhooks using pure code nodes
Created by: Alex Raj || alex-web-codes
Alex Raj
Last update 2 months ago
Categories
Quick overview
This workflow exposes two webhooks to train and run inference for a 3-hidden-layer neural network built entirely with n8n Code and Merge nodes, persisting learned weights in workflow static data and returning class probabilities, predictions, and evaluation metrics.
  1. Receives a POST request on /train with epochs, learning rate, and an optional dataset to train the network.
  2. Runs a vectorized forward and backpropagation pass in JavaScript, updates weights and biases with gradient descent, and stores them in n8n workflow static data.
  3. Receives a POST request on /predict containing one or more 8‑dimensional feature vectors (and optional trueClass labels).
  4. Computes a feedforward pass through three ReLU hidden layers (9 neurons per layer) using the stored weights (or deterministic fallback weights if none are trained).
  5. Produces 4 output logits, applies a temperature-scaled softmax to return probabilities, predicted class, and confidence.
  6. Calculates per-sample cross-entropy loss and batch accuracy using trueClass (when provided) and responds with the prediction results as JSON.
  1. Activate the workflow and copy the production webhook URLs for POST /train and POST /predict.
  2. Send training data to /train (or rely on the default dataset) to initialize and persist weights in workflow static data.
  3. Send inference requests to /predict as JSON containing x: [8 numbers] (optionally add sampleId and trueClass: 1..4) and review the JSON response for probabilities, predictions, loss, and accuracy.
