Monitor competitor price shifts with Apify, Postgres, OpenAI, and Slack
Created by: Apify || apify
Apify
Last update 9 days ago
Categories
Quick overview
This workflow runs every morning to scrape competitor product pages with Apify, store daily price snapshots in Postgres/Supabase, detect unusual price moves using SQL views, and post actionable repricing commentary (plus scraping health warnings) to a Slack channel.
  1. Every morning it reads your list of competitor product URLs and sends them to the Apify E-commerce Scraping Tool, which handles anti-bot, proxies and per-retailer extraction. There is no scraper to maintain here.
  2. A normalize step reduces per-retailer differences to one shape. Prices are parsed without assuming a locale, so 1.299,99 and $1,299.99 both read correctly. Currency is stored as an ISO code rather than a symbol. Stock keeps three states, because "not reported" is not the same as "out of stock".
  3. One row per product per day goes to Postgres. A view compares today against the trailing 30-day average and the 90-day low and reports transitions, not states, so a rival who cuts a price and holds it is reported once rather than every morning. It stays silent for the first 14 days, because a baseline of one day is noise.
  4. An AI agent turns what moved into a recommendation and posts it to Slack. A second branch reports which URLs returned nothing, so a broken page cannot look like a quiet market.
  1. Add the Apify community node. On n8n Cloud, search for it on the canvas; your instance owner must have verified community nodes enabled. Self-hosted, install @apify/n8n-nodes-apify under Settings, Community nodes.
  2. Run the schema in supabase_schema.sql (linked in the sticky note) against Postgres 15 or later. It creates a private schema with RLS enabled, so the table is never exposed through Supabase's Data API.
  3. Add credentials: Apify, Postgres, a chat model, Slack.
  4. Open Pages to watch and replace the example URLs with yours, and set your Slack channel.
  5. Check your instance timezone. The schedule says 06:00 and n8n reads that in the instance timezone.
  6. Run once manually and confirm a row landed in pricing.price_history.
Requirements
  • An Apify account.
  • Postgres 15 or later, or a Supabase project. Version 15 is the floor because the views use security_invoker.
  • A chat model credential and a Slack workspace.
Customization
  • The detection thresholds live in one SQL view: the 5% band against the 30-day average, the 90-day low and high, and the 14-day baseline gate. Change them there and the agent's behaviour follows, because detection is deterministic and the model only writes.
  • Swap Slack for email, Sheets or a webhook by replacing one node. To watch a category rather than fixed products, run the Actor in keyword mode once to harvest URLs, then pin them: keyword results drift daily and cannot produce a price series.
