Triage Connectively tech questions with OpenAI and send alerts to Telegram
Created by: Eugene || regyl
Eugene
Last update 4 days ago
Categories
Quick overview
This workflow allows you to fetch questions from Connectively and check if the questions match your background. If so, it sends a notification to your Telegram account with the question and AI-based reasoning.
  1. Runs every hour on a schedule.
  2. Logs in to Connectively via its API and fetches questions.
  3. Filters by Technology category and removes questions already seen in previous executions.
  4. Filters questions by asking an OpenAI-compatible model to decide whether to answer based on the background you provided.
  5. Sends the matched question to Telegram.
  1. Fill the login & password for "Authorize" node. Hint: Credentials can be obtained from https://www.connectively.us/api-integration/sign-up
  2. Fill your background at "Message a model" node. Hint: You can use either OpenAI's paid APi or a self-hosted LLM like google/gemma-4b through LM Studio.
  3. Fill your Telegram chat id at "Send notification" node
Requirements
  • Telegram account
  • Self-hosted LLM or OpenAI account
  • Connectively credentials (free tier)
