Quick overview
This workflow exposes two web pages that let you enter a Base chain pool address, fetches market and pool data from GeckoTerminal plus token security checks from GoPlus and Honeypot.is, and uses DeepSeek to generate a risk verdict and render an interactive chart and analysis report.
- Receives a GET request on the landing-page webhook and returns an HTML form for entering a Base pool address.
- Receives a GET request on the analysis webhook with
address, tf, and agg query parameters and normalizes defaults for missing values.
- Pulls OHLCV candles, recent trades, and pool metadata for the provided pool from the GeckoTerminal API.
- Extracts the base token contract address from the pool metadata and queries GoPlus Labs and Honeypot.is for token security and honeypot simulation results.
- Aggregates candles and trades into summary statistics and builds a structured prompt that instructs DeepSeek to return a strict JSON risk assessment.
- Sends the prompt to the DeepSeek Chat Completions API and parses the returned JSON verdict, confidence, tags, analysis, and suggestion.
- Renders an HTML results page with the AI assessment, a Lightweight Charts candlestick/volume chart, and a recent-trades table, then returns it to the browser.
- Create a DeepSeek API credential using HTTP Header Auth with
Authorization: Bearer <your_api_key> and select it in the DeepSeek request step.
- Activate the workflow and copy the production URL for the
/base-pool-scanner webhook to use as your entry point.
- Ensure your n8n instance can make outbound HTTPS requests to
api.geckoterminal.com, api.gopluslabs.io, api.honeypot.is, and api.deepseek.com, and allow access to the unpkg.com CDN if you want the embedded chart to load.
- Optionally adjust the default timeframe (
tf) and aggregation (agg) values in the analysis URL parameters to match the candle granularity you want.
