Quick Overview
This workflow runs weekly to fetch Similarweb-based AI chatbot referral share and traffic estimates for a list of competitor domains via Apify, appends new monthly data to a Google Sheets History tab, and posts a Slack alert when chatbot share or visit changes exceed your thresholds.
- Runs manually or every Monday at 08:00 to start the check.
- Sends your list of domains to an Apify actor that returns Similarweb estimates, including monthly visits, AI chatbot visit share, and per-chatbot splits.
- Reads existing rows from the Google Sheets “History” tab and compares each domain’s newest month to the latest saved month.
- Creates new rows only when a new traffic month is available, calculates notable changes against the previous month, and flags domains that pass your share-point or visit-change thresholds.
- Appends the new month rows to the Google Sheets “History” tab.
- Builds a combined message for all flagged domains and posts it to a Slack channel, or posts a failure note to Slack if the Apify run errors.
- Add an Apify API token credential and ensure the Apify community node (
@apify/n8n-nodes-apify) is installed in your n8n instance.
- Connect Google Sheets OAuth credentials, create a spreadsheet with a tab named “History”, and replace the spreadsheet ID in both Google Sheets steps.
- Connect Slack credentials and set the target channel (for both the alert and failure message), then update the domain list and alert thresholds in the settings step.
