Quick overview
Monitors FortiGate SD-WAN link health and real-time bandwidth usage. Sends Gmail reports and alerts for WAN outages, congestion, and slow connections. Supports secure, passphrase-verified email commands to identify the top bandwidth user and optionally clear their sessions through SSH, enabling automated network visibility, troubleshooting, and traffic management.
- Triggers either when a matching Gmail message is received or every 10 minutes on a schedule.
- Parses the newest allowed email command to decide whether to run a read-only report or request a session clear, and loads the full email to verify the sender for kill requests.
- Queries the FortiGate REST API for SD-WAN members, health-check status, interface bandwidth capacity, and FortiView top sources and destinations.
- Analyzes WANs as OK/SLOW/CHOKED/DOWN based on capacity, latency, and packet loss thresholds, and selects an eligible top private-IP bandwidth user that is not in the protected list.
- If a verified email command requests it, connects to the FortiGate via SSH to clear sessions for the selected top source, waits 10 seconds, and re-queries top sources and SD-WAN members.
- Builds an HTML email report and sends it via Gmail for every email command, or only on WAN problems and once on recovery for scheduled monitoring.
- Create a FortiGate REST API admin and add an n8n HTTP Header Auth credential with an Authorization Bearer token for the FortiGate API requests.
- Create a FortiGate CLI admin with SSH access from your n8n host and configure an SSH credential for the session-clearing step.
- Connect a Gmail account for reading command emails and sending reports, then update the Gmail search query to include your chosen passphrase.
- In the workflow settings values, set your FortiGate URL, allowed sender emails, report recipient, WAN interface names, protected IPs, and any thresholds (choke/latency/loss, cooldown, top N).
