Quick overview
Audits only changed Figma frames against your design system: contrast, font size, tap targets, unlinked tokens and detached components. A Gemini agent reviews each screenshot with your design guide. New issues become Figma comments, fixed ones get a ✅ reply, and Slack gets summaries and weekly reports.
- Triggers when a Figma named version is saved via webhook, when someone submits the audit request form, or every Monday at 9:00.
- Validates the request (including the Figma webhook passcode), loads the design guide from Google Docs, and fetches the Figma file structure.
- Selects the target page, lists top-level frames, compares frame fingerprints against the stored snapshots in n8n Data Tables, and keeps only frames that changed (or forces a review for form requests).
- For each changed frame, runs deterministic checks on the Figma node tree for contrast, font size, tap targets, token/style usage, and possible detached components, then loads any still-open findings for that frame.
- Exports a PNG screenshot from Figma and sends it, the layer index, the design guide, and open issues to a Google Gemini agent that proposes new issues and marks previously reported AI issues as resolved when they appear fixed.
- Reconciles new, still-open, and fixed findings by pinning new comments in Figma, replying in existing threads for fixed items, and updating the findings and frame snapshots in n8n Data Tables.
- Posts an audit summary to a Slack channel after each run and posts a weekly design-health report to Slack based on the stored findings and frame metrics.
- Create a Figma personal access token with access to read file content and write comments, and configure it as HTTP Header Auth for all Figma API requests (including the layer-inspection tool) and set a webhook passcode.
- Add Google Docs OAuth credentials for reading your design guide and update the design guide document URL in the workflow configuration.
- Add a Google Gemini API credential for the Gemini chat model used by the agent.
- Add Slack credentials and set the target channel ID in the workflow configuration.
- Update the workflow configuration values (page name, review focus, thresholds, limits, and timezone), and if using the Figma trigger, register a Figma FILE_VERSION_UPDATE webhook pointing to the production webhook URL with the same passcode.
Requirements
- Figma account with a personal access token (file content read, comments write)
- Google Gemini API key
- Google account with the design guide in Google Docs
- Slack workspace with a bot (chat:write) invited to the target channel
- n8n with Data Tables (n8n Cloud or a recent self-hosted version)
Customization
- Change contrast, font size and tap-target thresholds or the per-run limits in Workflow Configuration
- Set reviewLanguage to get Figma comments in another language
- Add your own rules in Run Design Checks; new rules are tracked and closed automatically like the built-in ones
- Replace the Slack nodes with Gmail or Microsoft Teams, or move the weekly report to another day
Additional info
Tested end to end on a Figma file with color variables, text styles, a component and a detached copy. On the second run, fixed issues received a "✅ Fixed" reply and reaction in their original comment threads, and unchanged frames were skipped.
