Quick overview
This workflow runs monthly (or manually) to search the OpenAlex API for recent autism-and-walking-related literature, scores and classifies results for relevance, deduplicates papers by DOI/title, and stores new items while updating previously seen items in an n8n Data Table.
- Runs on a monthly schedule (with an optional manual run for testing) and loads a predefined Boolean search strategy.
- Generates 18 reproducible search queries by combining the identity, action, and site term blocks.
- Queries the OpenAlex Works API for each search and limits results to the last month and the top five matches per query.
- Extracts paper metadata and reconstructs abstracts from OpenAlex’s inverted index while recording which search combination retrieved each paper.
- Applies a deterministic keyword-based scoring model to classify each paper as RELEVANT, POSSIBLY RELEVANT, or NOT RELEVANT and stores match evidence.
- Deduplicates papers using DOI (or a normalized title fallback) while preserving all retrieval routes and a retrieval count.
- Checks each unique paper against an n8n Data Table, inserting new rows with first/last seen timestamps and updating existing rows with a refreshed last seen date and status.
- Create or select an n8n Data Table for your literature library and map it in the Data Table nodes used for the “row exists/does not exist”, insert, and update operations.
- Review and edit the search strategy term blocks (identity/action/site) and adjust the OpenAlex query settings (date window, per-page limit) to match your research scope.
- Set the schedule trigger timing to your preferred monthly run time, or disable it and use the manual trigger during development.
