Monitor nighttime system health with Google Sheets, GPT-4o-mini and Gmail
This template automates overnight system health monitoring for DevOps and IT operations teams. It checks your internal services and APIs on a schedule, logs all results to Google Sheets, and sends AI-generated alert emails when something goes wrong.
Who this is for
System administrators, DevOps engineers, and IT operations teams who need lightweight, automated overnight monitoring — without setting up a full-scale monitoring platform.
What's included
A single workflow that handles the full monitoring loop:
  1. Read Monitor Targets — Reads active URLs from Google Sheets. Add or disable targets anytime without touching the workflow.
  2. Health Check — Sends HTTP GET requests with a 3-second timeout to each target.
  3. Response Time Tracking — Measures and logs response time in milliseconds for every check.
  4. Full Result Logging — Appends every check result (OK and ERROR) to a Google Sheets log with timestamp, status, status code, response time, error message, and alert status.
  5. AI-Generated Alert — On failure, GPT-4o-mini generates a structured Japanese alert message with situation summary, urgency level, first steps to check, and escalation guidance.
  6. Gmail Alert — Sends the alert email to a configured address with a clear subject line.
  7. Alert Status Tracking — Updates the log to mark when an alert has been sent.
Key features
  • Manage all monitoring targets in Google Sheets — no workflow edits needed to add or remove URLs
  • Monitors both HTTP errors (503 etc.) and connection failures (timeout, ECONNREFUSED)
  • Logs every check result for uptime analysis and audit purposes
  • AI alert in Japanese with actionable first-response guidance
  • Configurable schedule via Cron expression (default: every 10 min, weekdays 1:00–4:59 AM)
  • Timezone follows your n8n instance setting — no hardcoded timezone
Prerequisites
  • Google Sheets (copy link provided in the workflow)
  • Gmail account connected to n8n
  • OpenAI API key
このテンプレートは、DevOpsおよびIT運用チーム向けに夜間のシステム死活監視を自動化します。スケジュールに従って社内サービスやAPIをチェックし、全結果をGoogle Sheetsに記録し、障害検知時にはAIが生成したアラートメールを送信します。
このワークフローの対象ユーザー
本格的な監視プラットフォームを導入せずに、軽量で自動化された夜間監視を必要としているシステム管理者・DevOpsエンジニア・IT運用担当者向けです。
含まれる内容
監視ループ全体を1つのワークフローで処理します:
  1. Read Monitor Targets — Google SheetsからアクティブなURLを読み込む。ワークフローを編集せずにいつでも監視対象を追加・無効化できる。
  2. Health Check — 各URLに3秒タイムアウトのHTTP GETリクエストを送信する。
  3. レスポンスタイム計測 — 全チェックのレスポンスタイムをミリ秒単位で計測・記録する。
  4. 全結果ログ — タイムスタンプ・ステータス・ステータスコード・レスポンスタイム・エラーメッセージ・アラート送信状況を含む全チェック結果(OKおよびERROR)をGoogle Sheetsに記録する。
  5. AIアラート生成 — 障害検知時、GPT-4o-miniが状況・緊急度・まず確認すべき手順・エスカレーション先をまとめた構造化された日本語アラートを生成する。
  6. Gmailアラート送信 — 設定したメールアドレスに、分かりやすい件名でアラートメールを送信する。
  7. アラート送信状況の記録 — アラート送信済みかどうかをログに更新する。
主な特徴
  • 監視対象のURLはすべてGoogle Sheetsで管理 — URLの追加・削除にワークフローの編集は不要
  • HTTPエラー(503等)と接続障害(タイムアウト・ECONNREFUSED)の両方を検知
  • 稼働率分析や監査目的のために全チェック結果を記録
  • 初動対応に役立つ日本語構造化アラートをAIが生成
  • Cron式でスケジュールをカスタマイズ可能(デフォルト:平日1:00〜4:59に10分ごと)
  • タイムゾーンはn8nインスタンスの設定に従う — ハードコードなし
前提条件
  • Google Sheets(ワークフロー内にコピー用リンクあり)
  • n8nに接続済みのGmailアカウント
  • OpenAI APIキー
