Generate tailored CV and Cover Letter from job links
  • This Workflow automatically creates a new CV and Cover Letter based on the job description and your Current CV.
How to set it up
  • Create API keys for Google sheet Link, Google Docs Link and OpenRouter link
    -- If you do not know how to create and add an API key, then simply search on Google, and you will find a solution.
  • Create a new Google Sheet in your Google Drive with the name "Job IDs" and also add 3 columns with names "JobLink, CoverLetter, and CV."
  • Then create a 2 Google Docs in your Google Drive with the names Cover Letter and CV.
  • Linked them with the respective node in the workflow
  • Add this code into Google sheet "APP Script" -> "function callN8n(e) {
    var range = e.range;
    if (range.getColumn() == 1) {
    // This is the combined URL from your terminal + n8n path
    var url = "https://pronounce-surround-curtsy.ngrok-free.dev/webhook/3d23f43d-9d38-45ba-9ad1-b696a2b97905";
    var options = {
    "method": "post",
    "headers": {
    "ngrok-skip-browser-warning": "true"
    "payload": JSON.stringify({
    "JobLink": e.value,
    "row": range.getRow()
    "contentType": "application/json"
    UrlFetchApp.fetch(url, options);
Contact Detail
