Monitor futures trades and send risk alerts using Binance, Sheets, Slack and email
Created by: WeblineIndia || weblineindia
WeblineIndia
Last update 3 months ago
Categories
Futures Trade Monitoring & Risk Alert Workflow
n8n, Binance API, Google Sheets, Slack, Telegram, Jira & Email
This workflow automates futures trade monitoring by fetching live prices from Binance, calculating trade performance (PnL, ROI, fees), evaluating risk levels and sending alerts across Slack, Telegram, Jira and Email. It also stores trade history and analytics in Google Sheets.
Quick Implementation Steps
  1. Import workflow into your n8n account.
  2. Configure trade input (Function or Google Sheets).
  3. Connect Slack, Telegram, Jira, Gmail credentials.
  4. Set up Google Sheets (Trades & Analytics).
  5. Run workflow or enable schedule trigger.
What It Does
This workflow continuously monitors futures trading positions by combining user-defined trade data with real-time market prices fetched from the Binance public API. It calculates key metrics such as profit/loss (PnL), return on investment (ROI) and transaction fees to evaluate trade performance.
Based on calculated values, the workflow applies a risk scoring mechanism to classify trades into different severity levels. These levels determine how alerts are routed across communication platforms such as Slack, Telegram, Jira and Email.
Additionally, the workflow stores all trade data and daily analytics in Google Sheets, enabling users to track performance trends and maintain a history of trades without manual effort.
Who It's For
  • Crypto futures traders
  • Trading teams and analysts
  • Risk management teams
  • Automation enthusiasts using n8n
  • Developers building trading dashboards
Requirements
  • n8n account (cloud or self-hosted)
  • Binance public API access (no API key required)
  • Google Sheets account
  • Slack workspace (optional)
  • Telegram bot (optional)
  • Jira account (optional)
  • Gmail account (optional)
How It Works & Setup Instructions
Step 1: Trigger Setup
Configure Schedule Trigger to run at intervals (e.g., every 5 minutes).
Step 2: Trade Input
Use Function node or Google Sheets to define:
  • symbol
  • entry_price
  • quantity
Step 3: Fetch Market Data
HTTP Request node calls Binance API:
  • Endpoint: /api/v3/ticker/price
Step 4: Merge Data
Merge node combines trade input with live price.
Step 5: Process Trade Metrics
Function node calculates:
  • PnL
  • Fees
  • Net PnL
  • ROI
Step 6: Filter Valid Trades
IF node ensures valid calculations (e.g., non-null values).
Step 7: Risk Scoring
Assigns risk score based on loss and position size.
Step 8: Alert Routing
Switch node routes alerts:
  • Low → Slack
  • Medium → Slack + Telegram
  • High → Slack + Telegram + Jira + Email
Step 9: Store Trade Data
Google Sheets (Trades):
  • Stores trade history
Step 10: Analytics
Function node generates:
  • Daily trade count
  • Net PnL summary
Step 11: Store Analytics
Google Sheets (Analytics):
  • Stores summarized data
How To Customize Nodes
  • Modify Function node to change trade input logic.
  • Adjust HTTP Request node for different APIs.
  • Update PnL logic for leverage or futures margin.
  • Modify risk scoring thresholds.
  • Customize alert messages per platform.
  • Change Google Sheets structure as needed.
Add-ons (Extend Functionality)
  • Duplicate alert prevention using Google Sheets lookup
  • Dashboard integration (Google Data Studio / Power BI)
  • Auto trade sync via exchange APIs
  • Webhook-based real-time alerts
  • Error handling and retry logic
Use Case Examples
  1. Monitor crypto futures trades in real time.
  2. Receive instant alerts for high-risk positions.
  3. Track daily profit/loss automatically.
  4. Manage multiple assets without manual checking.
  5. Enable centralized monitoring for trading teams.
Note: This workflow can be adapted for many other financial monitoring and automation use cases.
Troubleshooting Guide
Issue Possible Cause Solution
PnL is null Incorrect field mapping Ensure correct price field is used
Telegram error Formatting issue Set Parse Mode to NONE
No alerts triggered Risk condition not met Check Switch node logic
Empty rows in Sheets Wrong data source Connect correct node to Sheets
API error Invalid request Verify Binance endpoint
Need Help?
If you need help setting up, customizing or extending this workflow, feel free to reach out our n8n workflow developers at WeblineIndia.
We can help you:
  • Customize workflows
  • Integrate additional APIs
  • Build scalable automation systems
  • Add advanced analytics and dashboards
  • And so much more.
