Back to TemplatesCapture and draft content ideas from Telegram with Claude and Notion
Last update 4 months ago
- Send any idea as a text message to a Telegram bot
- Claude automatically decides the best content format (carousel, reel, or blog post)
- Claude writes 3 hooks for that format — problem, curiosity, and contrarian angles
- Each hook gets a full content draft
- Everything lands in a Notion database — tagged, formatted, and ready to use
- A Telegram confirmation is sent back with your hooks instantly
Set up steps
- Create a Telegram bot via BotFather and connect it to n8n
- Add your Anthropic API key to the Claude node
- Duplicate the Notion database template (link in sticky note inside workflow)
- Connect your Notion account to n8n
- Activate the workflow and send your first idea
