Recommend TikTok sound and caption packs for AI product videos with Wouldliker
This workflow turns a product or short-form clip description into a
publishable Wouldliker sound pack.
  1. A webhook receives the clip or product description.
  2. The workflow normalizes the input into Wouldliker API fields.
  3. POST /api/recommend returns the recommended Wouldliker sound, official
    TikTok sound URL, TikTok music ID, public proof, and sound direction.
  4. POST /api/brief returns a short video brief, caption variants, hashtag
    pack, and boundary copy.
  5. The final node shapes a flat object for downstream tools.
Use it inside AI-video, ecommerce video, UGC, content ops, product feed, or
short-form publishing workflows.
Set up steps
Setup takes about 5 minutes.
  1. Import the template.
  2. Execute the workflow once to enable the test webhook.
  3. Send a POST request to the webhook with description, platform,
    content_type, language, and is_aigc.
  4. Connect the final output to your own publisher, CMS, Slack, Notion,
    Airtable, Shopify, or content queue.
No credentials or API keys are required.
Boundaries
Wouldliker returns recommendation data only.
  • It does not auto-post to TikTok.
  • It does not download or redistribute audio.
  • It does not guarantee views.
  • The publisher attaches the returned tiktok_sound_url or tiktok_music_id
    in their own upload step.
  • If is_aigc is true, the publisher is responsible for platform disclosure
    and labeling.
Public proof is evidence of fit and momentum
