Extract business card contacts with LDX hub Gemini AnalyzeDoc and Google Sheets
Created by: Hideki Mori || hidekimori
Hideki Mori
Last update a month ago
Categories
Quick overview
This workflow collects a business card photo/scan through an n8n form, uses LDX hub AnalyzeDoc (Gemini) to extract contact details as structured JSON, and appends the resulting fields as a new row in Google Sheets.
  1. Receives a business card file upload (PDF/JPG/PNG) through an n8n form submission.
  2. Sends the uploaded file to LDX hub AnalyzeDoc using the Gemini model and a fixed schema prompt to extract contact fields as JSON.
  3. Parses the extracted JSON into individual fields like name, company, email, phone numbers, and address.
  4. Appends the extracted fields as a single new row in the selected Google Sheets worksheet.
  1. Install the community node n8n-nodes-ldxhub and add an LDXhub API credential with your API key.
  2. Add a Google Sheets OAuth2 credential and select the target spreadsheet and worksheet in the append step.
  3. Create (or match) a header row in your sheet for full_name, job_title, company, department, email, phone, mobile, address, website, notes so the auto-mapping writes to the correct columns.
