Enrich company records with social media links using GPT-4o and Supabase
Quick overview
This workflow is manually triggered to pull company names and websites from Supabase, crawl each site with an OpenAI-powered agent to extract social media profile URLs, and write the enriched results to a separate Supabase table.
  1. Runs when you manually execute the workflow.
  2. Reads all rows from the Supabase companies_input table and keeps the name and website fields for processing.
  3. Uses an OpenAI (GPT-4o) agent to crawl the company website, following discovered links and extracting social media profile URLs.
  4. Forces the agent output into a structured JSON schema and maps the extracted links into a social_media array.
  5. Merges the original company name and website with the extracted social media data.
  6. Inserts the enriched record into the Supabase companies_output table.
  1. Add a Supabase credential and set the correct project details for both reading from companies_input and writing to companies_output.
  2. Add an OpenAI API credential for the GPT-4o chat model used by the crawling agent.
  3. Ensure your input table has name and website fields or update the field selection and mapping to match your schema.
  4. Confirm the output table accepts the mapped fields (for example company_name, company_website, and social_media) when auto-mapping input data.
