Score inbound form leads with OpenAI and send hot leads to Slack and Sheets
Quick Overview
This workflow collects n8n Form submissions, uses OpenAI (GPT-4o-mini) to score each lead from 1–10 with reasoning, posts hot leads (score ≥ 7) to Slack, and appends all scored leads to Google Sheets for tracking.
  1. Triggers when a new submission is received from an n8n Form.
  2. Sends the submitted details to OpenAI (GPT-4o-mini) to generate a 1–10 lead score and brief reasoning.
  3. Extracts the numeric score and reasoning from the OpenAI response and structures the lead record.
  4. Checks whether the lead score is 7 or higher.
  5. Posts a formatted hot-lead alert to a selected Slack channel when the score is 7+.
  6. Appends the lead details, score, and reasoning to a Google Sheets spreadsheet for logging.
  1. Add an OpenAI credential for the OpenAI Chat Model node.
  2. Add a Slack credential and replace the channel selection (e.g., the channel ID) used for hot-lead alerts.
  3. Add a Google Sheets OAuth credential and set the target Spreadsheet ID and sheet/tab for logging.
  4. Update the lead-scoring prompt text if you want different criteria or a different “hot lead” threshold.
