Monitor NASA space weather and DSN anomalies with OpenRouter and Telegram
Created by: Ali Abdullah || ali-abdullahx1
Ali Abdullah
Last update 16 days ago
Categories
Quick overview
This workflow runs every 5 minutes to fetch NASA DSN status, NASA DONKI CME events, NOAA GOES X-ray flux, and NASA NeoWs near‑Earth object data, then uses an OpenRouter-hosted LLM to generate a brief and sends it to Telegram while logging it in PostgreSQL.
  1. Runs every 5 minutes on a schedule.
  2. Fetches Deep Space Network antenna status from NASA’s DSN XML feed and pulls recent CME events from NASA DONKI using your NASA API key.
  3. Fetches the last 6 hours of NOAA GOES X-ray flux data and today/tomorrow near‑Earth object feed data from NASA NeoWs using your NASA API key.
  4. Aggregates all sources into a single summary, including DSN tracking/maintenance counts, potential downlink anomalies, CME totals, X-ray classification, and hazardous asteroid names.
  5. Sends the summary to an OpenRouter chat model to produce a short, structured monitoring brief with status, actions, and verdict.
  6. Sends the generated brief to a Telegram chat and stores the alert text plus raw context data in a PostgreSQL table.
  1. Add an OpenRouter API credential and ensure the selected model is available in your OpenRouter account.
  2. Add a Telegram Bot credential, then set your target chat ID and bot token (and update the chat ID variable in the workflow).
  3. Provide a NASA API key (api.nasa.gov) and update the nasaApiKey variable in the workflow.
  4. Add PostgreSQL credentials and create an aegis_alerts table that matches the insert query columns used by the workflow.
  5. Review the schedule interval (default: every 5 minutes) and adjust it to match your desired monitoring cadence.
Requirements
  • NASA API key (free from api.nasa.gov)
  • Telegram Bot token and chat ID
  • PostgreSQL database with a aegis_alerts table
  • OpenRouter API key
Customization
  • Adjust the Schedule Trigger interval to change monitoring frequency
  • Add more data sources by duplicating fetch nodes
  • Change alert channel from Telegram to Slack or Email
  • Modify anomaly thresholds inside the Code node
Additional info
This template uses only core n8n nodes and free public APIs (NASA, NOAA). No external subscriptions are required.
