Quick overview
This workflow runs every 10 minutes to monitor a DeFi lending position by fetching position and price data via HTTP, calculating liquidation risk metrics, logging results to Google Sheets, and sending AI-written Slack alerts (via OpenAI) when the risk level changes or escalates.
- Runs every 10 minutes on a schedule.
- Loads the monitoring configuration, including the lending position API URL and the asset price API URL.
- Fetches the current lending position via HTTP and continues only if collateral amount, debt amount, and liquidation threshold are greater than zero.
- Fetches the live collateral asset price via HTTP and continues only if the USD price is greater than zero.
- Calculates health factor, estimated liquidation price, and distance to liquidation, then classifies the position risk level and determines whether an alert is required based on the previous risk level.
- Appends each monitoring result to a Google Sheets “Monitoring History” worksheet.
- When an alert is required, OpenAI generates a concise risk summary which is posted to a Slack channel and recorded in a Google Sheets “Alert History” worksheet.
- Provide reachable HTTP endpoints for the lending position API and the asset price API, then update the two URLs (and any threshold values) in the configuration step.
- Add Google Sheets credentials and select the target spreadsheet and worksheets for “Monitoring History” and “Alert History.”
- Add an OpenAI API credential and ensure the selected model is available in your OpenAI account.
- Add Slack credentials and set the destination channel for liquidation risk alerts.
- Adjust the schedule interval if you want a different monitoring cadence.
Additional info
How To Customize Nodes
Schedule Monitoring Cycle: Change the monitoring frequency from the current 10-minute interval.
Load Monitor Configuration: Change API endpoints and health factor thresholds.
Calculate Risk Metrics: Modify the liquidation-risk calculations if the position data model changes.
Classify Liquidation Risk: Adjust risk-level boundaries and alert escalation behavior.
Generate Risk Alert Message: Customize the OpenAI prompt or selected model while keeping the supplied risk data as the source of truth.
Add-ons
The following are optional extensions and are not part of the current workflow:
- Email fallback alerts when Slack delivery fails.
- Additional lending positions so multiple wallets or positions can be monitored.
- Separate Google Sheets reporting for daily or weekly risk summaries.
- Historical health-factor trend analysis.
- Additional notification channels for critical or breached liquidation states.
Use Case Examples
- Collateral Monitoring: Track an ETH-backed lending position and identify declining health factor levels.
- Risk Escalation Alerts: Notify a Slack channel when a position moves from a safe state into a warning or higher-risk state.
- Liquidation Distance Tracking: Store current price, estimated liquidation price, and liquidation distance for historical review.
- Operational Risk History: Maintain a Google Sheets record of every monitoring cycle for later analysis.
- AI Risk Summaries: Convert calculated risk metrics into concise, human-readable alert messages.
Additional use cases may be possible through customization.
Troubleshooting Guide
| Issue |
Possible Cause |
Solution |
| No lending position data |
The configured position API endpoint is unavailable or returns an unexpected structure |
Verify position_api_url and confirm the response contains collateral amount, debt amount, and liquidation threshold |
| Market price validation fails |
The price response does not contain a positive price_usd value |
Verify the configured price API and its response structure |
| Health factor is incorrect |
Position fields or liquidation threshold do not match the expected data format |
Review the response fields used by Calculate Risk Metrics |
| No Slack notification |
alert_required is false or Slack credentials/channel configuration is incorrect |
Check the risk classification and verify Slack configuration |
| AI message is not normalized |
The OpenAI response does not contain the expected text structure |
Review the OpenAI output and the parsing logic in Normalize AI Risk Alert |
| Google Sheets logging fails |
Spreadsheet credentials, sheet selection, or column mappings are incorrect |
Verify Google Sheets credentials, selected sheets, and required column names |
Need Help?
WeblineIndia can assist with workflow setup, API and credential configuration, Google Sheets and Slack integration, workflow customization, troubleshooting, optional add-ons and development of similar n8n automation workflows.
