Manage fleet compliance and driver renewals with Sheets, OpenAI and Telegram
Created by: Rahul Joshi || rahul08
Rahul Joshi
Last update 3 days ago
Categories
Quick overview
This workflow runs a daily compliance scan from Google Sheets, checks each vehicle’s document expiries and pending e-challans via an HTTP API, then uses OpenAI to message drivers on Telegram, create renewal tasks in ClickUp, notify ops in Slack, and email Gmail digests to fleet managers.
  1. Runs every day at 7 AM on a schedule trigger.
  2. Reads the Fleet_Register and Alert_Log tabs in Google Sheets to evaluate RC/insurance/PUC/fitness/permit expiries and dedupe alert stages per vehicle.
  3. Calls your e-challan provider over HTTP to fetch pending challans, calculates a 0–100 risk score, and sets the vehicle dispatch status to BLOCKED if any document is expired.
  4. When dispatch status changes, updates the vehicle’s status in Google Sheets and posts a dispatch gate alert to an ops Slack channel.
  5. For vehicles needing action, uses OpenAI (gpt-4o-mini) to generate a driver Telegram message plus manager summary, creates a ClickUp renewal task when needed, sends the driver alert on Telegram, and appends the alert keys/task keys to the Alert_Log sheet.
  6. Groups all vehicles needing action by manager email, builds an HTML digest, and sends each fleet manager a daily summary email via Gmail.
  7. When a driver sends a document photo to the Telegram bot, the workflow downloads the image, uses OpenAI (gpt-4o) to extract document type/vehicle number/valid-until, validates it against the register, updates Google Sheets if valid, notifies ops in Slack to spot-check, and confirms (or rejects) the upload to the driver on Telegram.
  1. Create a Google Sheet with Fleet_Register (vehicle_no, document expiry columns, dispatch_status, blocked_reason, driver_telegram_chat_id, manager_email, chassis_last5) and Alert_Log (logged_at, alert_keys, task_keys, etc.) tabs, and put its ID into all Google Sheets nodes.
  2. Add credentials for Google Sheets, OpenAI, Telegram Bot, Slack, ClickUp, and Gmail.
  3. Configure the e-challan provider HTTP request with your API URL and HTTP Header Auth credential, and ensure chassis_last5/vehicle_no values match what the provider expects.
  4. Set your Slack channel ID, and your ClickUp team/space/list IDs used for renewal task creation.
  5. Enable the Telegram trigger by setting the bot webhook (copy the n8n Telegram trigger URL into BotFather/webhook setup as required) and ensure each driver’s Telegram chat ID is present in Fleet_Register so unknown senders are ignored.
