Quick overview
This workflow runs hourly to check an HTTPS JSON endpoint for expected HTTP status and business-rule assertions, deduplicates repeated failures using n8n static data, and posts failure or recovery alerts to a Slack channel.
- Runs every hour (or on manual execution) and loads the monitor configuration, including the target URL, expected status code, Slack channel ID, and up to four JSON field checks.
- Validates the configuration and converts the check rows into structured assertions.
- Sends an HTTP GET request to the target HTTPS endpoint and captures the full JSON response and status code.
- Evaluates the response against the expected HTTP status and the configured business checks (equals, nonEmpty, minItems, or freshWithinMinutes) and produces a healthy/unhealthy result with issue codes.
- Compares the current result to the previous run stored in n8n static workflow data to detect new failures, changed failures, reminder-worthy ongoing failures, or recoveries.
- Posts a formatted alert message to Slack only when an alert is needed, otherwise it completes silently.
- In the “EDIT HERE — URL, Checks & Alerts” node, set your HTTPS JSON GET endpoint, expected HTTP status, Slack channel ID, reminder interval, and at least one JSON path check with a supported rule.
- Configure authentication in the HTTP Request node if your endpoint requires it (for example, Header Auth with an Authorization bearer token or X-API-Key).
- Add a Slack credential with permission to post messages (chat:write), invite the bot to the target channel, and keep the workflow’s Slack channel selection bound to the configured channel ID.
