Monitor SSL certificate expiries with Google Sheets, Slack and Linear
Last update 4 months ago
Categories
8AM daily trigger
-   Read domains from Google Sheet
-   Check each domain's SSL certificate
-   Filter: only domains expiring within 30 days or already expired
-   Classify severity (expired / critical / warning / notice)
-   Send one digest message to Slack
-   Create a Linear issue[or Jira ticket] per critical or expired domain
-   Append all flagged domains to the logs sheet
Set up steps
Setup takes about 8–12 minutes.
1. Google Sheets
Create a spreadsheet with two sheets or download this:
Sheet 1 is called domains and sheet 2 logs
2. Import the workflow
Import this template into your n8n instance.
3. Connect credentials
You need three credentials:
  • Google Sheets
  • Slack
  • Linear API
