Fingerprints the technologies behind each website you list through Apify (CMS, e-commerce platform, analytics, CDN, frameworks) and scores each site for fit with your offer. Typical uses: find stores on a platform you build apps for, spot sites with no analytics or security tooling to pitch, or track which competitors' customers run which stack.
dedupeMemoryDays).aiCriteria and returns a fit score, verdict, summary, outreach angle and red flags. Calls are batched with a delay for rate limits, retried, and fall back to the rule score if the model fails.Authorization, value Bearer <APIFY_API_TOKEN> (Apify Console > Settings > API & Integrations). Select it on the 3 Apify HTTP nodes.sheetTab and a header row matching the sheet columns (see Upsert to Google Sheets, plus status and reviewedAt). Paste its ID into googleSheetId.slackChannelId and digestEmail in Config (also the channel on Slack: error alert).actorInput.urls, then targetTechnologies (lowercase tool names you sell into), targetCategories, gapCategories (categories whose absence is your pitch) and minConfidence.aiCriteria; set aiWeight (0 = rules only, 1 = AI only).categoriesFilter or technologiesFilter in actorInput to narrow the output.$json.Disclosure: I maintain these Apify actors (account transparent_meteorite). The actor is a paid pay-per-event Apify tool; check its Store page for current pricing before scheduling.
