Searches Hacker News for the keywords you care about and reads npm and PyPI download and release data for the packages you list. Stories are scored on points, comments, Show HN or Ask HN format and recency; packages on weekly downloads and release activity. Built for devrel, product marketing, open-source maintainers and investors watching developer mindshare.
- Daily schedule / manual run reads every setting from Config. A weekly schedule uses the same Config to send a report instead of running the actor.
- Starts the Apify actor asynchronously, then waits and polls the run; FAILED, ABORTED, TIMED-OUT or too many polls stop with an error.
- Downloads the dataset, validates rows and dedupes within the run and across runs (workflow static data,
dedupeMemoryDays).
- A transparent rule score runs first, then an LLM chain with a structured output parser reads each record against your plain-English
aiCriteria and returns a fit score, verdict, summary, outreach angle and red flags. Calls are batched with a delay for rate limits, retried, and fall back to the rule score if the model fails.
- Upserts every row to Google Sheets. Hot rows go to Slack as one approve / dismiss message (send-and-wait, 24 h limit) and the decision is written back to the sheet; warm rows go to an HTML email digest; cold rows stay in the sheet.
- Weekly report: reads the sheet, summarises the last 7 days (tiers, approvals, top 10) and emails it.
- A separate Error Trigger branch posts any failure to Slack.
Setup (about 15 minutes)
- Create an HTTP Header Auth credential: name
Authorization, value Bearer <APIFY_API_TOKEN> (Apify Console > Settings > API & Integrations). Select it on the 3 Apify HTTP nodes.
- Create a Google Sheet with a tab named in
sheetTab and a header row matching the sheet columns (see Upsert to Google Sheets, plus status and reviewedAt). Paste its ID into googleSheetId.
- Connect OpenAI (or swap the chat model sub-node for Anthropic, Gemini, Ollama...), Slack and Gmail; set
slackChannelId and digestEmail in Config (also the channel on Slack: error alert).
- In Config set
actorInput.hnKeywords, npmPackages, pypiPackages, sinceDate, then watchTerms, minPoints and hotWeeklyDownloads for your market size.
- Write your ideal-lead description in
aiCriteria; set aiWeight (0 = rules only, 1 = AI only).
- Run once manually, check the sheet, then activate.
Customize
- Edit weights in Score developer signal (points 40, comments 20, format 10, recency 15 for stories; downloads 35 and release recency 20 for packages).
- Use
hnDomains in actorInput to track every submission from a given domain (for example your own docs site).
- Package rows are keyed per package, so a package alerts once; remove its sheet row to re-alert.
- Swap Gmail/Slack for Teams, Discord, HubSpot, Airtable, etc. Each delivery node only reads
$json.
Disclosure: I maintain these Apify actors (account transparent_meteorite). The actor is a paid pay-per-event Apify tool; check its Store page for current pricing before scheduling.
