Two-way sync between Pipedrive and HubSpot
Created by: Lorena || lorenanda
Lorena
Last update 2 months ago
Categories
This workflow synchronizes data both ways between Pipedrive and HubSpot.
  • Cron node schedules the workflow to run every minute.
  • Pipedrive and Hubspot nodes pull in both lists of persons from Pipedrive and contacts from HubSpot.
  • Merge1 and Merge2 nodes with the option Remove Key Matches identify the items that uniquely exist in HubSpot and Pipedrive, respectively.
  • Update Pipedrive and Update HubSpot nodes take those unique items and add them in Pipedrive and HubSpot, respectively.
