Triage GitHub issues with GPT-4.1-mini, Slack, Gmail, ClickUp and Sheets
This workflow automatically handles new GitHub issues by reading and understanding them using AI, then taking multiple actions simultaneously — creating tasks, sending notifications, and keeping everything organized — without any manual effort.
Step-by-step
  • Trigger & filter
    • GitHub Trigger – Listens for issue events on a GitHub repository.
    • If – Filters to only process issues with the action opened.
  • AI analysis
    • Message a model – Sends the issue title, body, and metadata to GPT-4.1-mini with a structured prompt to extract category, subcategory, severity, priority, estimated effort, assigned team, summary, and suggested action.
    • Parse AI Response – Converts the raw AI text output into a clean structured JSON object and appends a formatted date.
  • Parallel output actions
    • Append row in sheet – Logs all issue data and AI analysis into a Google Sheets tracker.
    • Create a task – Creates a prioritized ClickUp task with full issue and AI analysis details.
    • Send a message – Posts a formatted Slack alert to #github-alerts with issue details and AI analysis.
    • Send a message1 – Sends an HTML-formatted email via Gmail with the full issue report and AI insights.
    • Create a comment on an issue – Posts the AI analysis summary as a comment directly on the GitHub issue.
    • HTTP Request – Applies AI-generated labels (category + severity) to the GitHub issue via the GitHub API.
Why use this?
  • Eliminates manual issue triage by using AI to instantly classify and prioritize every new issue
  • Keeps the entire team informed across Slack, Email, and GitHub simultaneously
  • Auto-creates ClickUp tasks so nothing falls through the cracks
  • Logs every issue to Google Sheets for reporting and trend analysis
  • Responds directly on GitHub so issue reporters get instant acknowledgment
