Auto tweet: spreadsheet-to-tweet automation
Last update 13 days ago
Categories
🎉 Do you want to master AI automation, so you can save time and build cool stuff?
I’ve created a welcoming Skool community for non-technical yet resourceful learners.
👉🏻 Join the AI Atelier 👈🏻
This is probably the most straightforward way to schedule your tweets. This n8n workflow addresses a simple problem: how to maintain consistency in your publications on X.
📋 Blog post
📺 Youtube Video
The workflow is direct and to the point.
In a Google spreadsheet, write all your tweets, one tweet per line.
Then, at a defined pace (for example, every 6 hours), the workflow will publish the first tweet from the list on your X account and remove it from the sheet.
This method is really simple but very efficient if you are looking for a direct and super fast solution to share regularly on X!
Created by the n8ninja.
