Business model canvas AI-powered generator (LLM flexible)
Created by: Sina || sina2266
Sina
Last update a month ago
👥 Who is this for?
  • Startup founders validating or pitching new ideas
  • Business consultants running strategy sessions
  • Product teams defining business logic visually
  • Agencies offering planning frameworks to clients
❓ What problem does this workflow solve?
Creating a Business Model Canvas manually is time-consuming and often scattered across tools. This workflow solves that by allowing users to generate a fully populated, formatted, and printable Business Model Canvas in seconds using the power of AI, all structured in a professional A4 landscape layout.
⚙️ What this workflow does
  • Starts with a chat input asking for your business idea
  • Sends it to 9 separate AI agents, each focused on one section:
    • Key Partners
    • Key Activities
    • Value Proposition
    • Customer Relationships
    • Customer Segments
    • Key Resources
    • Channels
    • Cost Structure
    • Revenue Streams
  • Uses your preferred LLM (see below) to generate meaningful bullet points
  • Converts output into a specific format
  • Merges all sections into a clean, A4-styled HTML canvas
  • Exports the result as a downloadable .html file
🛠️ Setup
  1. Import the workflow into your n8n instance
  2. Start the flow from the “When chat message received” node
  3. Describe your business idea when prompted (e.g., “Online bookshop with rare Persian literature”)
  4. Wait for AI processing to complete
  5. Visit the last node “HTML code to HTML file”
  6. Click Download to get your final canvas in .html format
🤖 LLM Flexibility (Choose Your Model)
This template supports any AI model with a chat interface:
  • Ollama (self-hosted models like LLaMA, etc.)
  • OpenAI (GPT-4, GPT-3.5)
  • Anything with a compatible node
You can easily change the LLM by updating the Language Model Node.
No need to modify any other logic or formatting.
🧪 How to customize this workflow
  • Change the LLM model from the Ollama node to OpenAI, etc.
  • Modify the final HTML layout in the “Turn to HTML” node
  • Add a PDF export, email delivery, or Google Drive sync
  • Replace the chat trigger with a webform, CRM hook, etc.
✅ Requirements
  • A working LLM integration (Ollama or OpenAI recommended)
  • n8n (self-hosted or cloud)
📌 Notes
  • Sticky notes included for setup and instructions
  • Each node clearly named by function (e.g. "Customer Segments Generator")
  • Designed for speed, structure, and professional presentation
📩 Need help?
For setup questions, custom features, or LLM integration support, contact:
[email protected]
