Send Prey missing-device alerts with Claude and Slack and log events to Sheets
Created by: Prey Team || paguzma
Prey Team
Last update 21 days ago
Categories
Quick overview
This workflow receives Prey device webhook events, sends device_missing incidents to Anthropic Claude to generate an urgent Slack alert, and appends both missing and non-missing device lifecycle events to a Google Sheets audit log.
  1. Receives a basic-authenticated POST webhook from Prey containing a device event payload.
  2. Checks the event type and routes device_missing events down an alert path while sending all other event types directly to logging.
  3. For device_missing events, extracts key device/owner details and the last-known GPS location to build a Google Maps link.
  4. Sends the missing-device context to Anthropic Claude to generate a concise three-sentence security alert for IT.
  5. Posts the AI-generated alert and Maps link to a specified Slack channel.
  6. Normalizes both missing and non-missing events into a flat schema and appends each event as a new row in Google Sheets.
  1. Create and select HTTP Basic Auth credentials in the webhook and use the same username/password when configuring the Prey webhook in the Prey Control Panel.
  2. Add an Anthropic API credential for the Claude model used to generate the missing-device alert.
  3. Add a Slack credential with permission to post messages and set the target channel ID in the Slack message step.
  4. Add a Google Sheets OAuth2 credential and replace the spreadsheet URL/ID and sheet name used for the append operation.
  5. Activate the workflow, copy the live webhook URL, and paste it into the Prey Control Panel webhook configuration.
Requirements
  • Prey account / Slack API KEY / Claude API KEY / Google Sheets API
