Clone viral TikTok & Instagram reels with Apify and Gemini 2.5 Pro
Created by: Lucas Walter || lucaswalter
Lucas Walter
Last update 8 months ago
Categories
Reverse engineer short-form videos from Instagram and TikTok using Gemini AI
Who's it for
Content creators, AI video enthusiasts, and digital marketers who want to analyze successful short-form videos and understand their production techniques. Perfect for anyone looking to reverse-engineer viral content or create detailed prompts for AI video generation tools like Google Veo or Sora.
This automation takes any Instagram Reel or TikTok URL and performs a forensic analysis of the video content. The workflow downloads the video, converts it to base64, and uses Google's Gemini 2.5 Pro vision API to generate an extremely detailed "Generative Manifest" - a comprehensive prompt that could be used to recreate the video with AI tools.
The analysis includes:
  • Visual medium identification (film stock, camera sensor, lens characteristics)
  • Color grading and lighting breakdown
  • Shot-by-shot deconstruction with precise timing
  • Camera movement and framing details
  • Subject description and action choreography
  • Environmental and atmospheric details
How to set up
  1. Configure API credentials:
    • Add your Apify API key for video scraping
    • Set up Google Gemini API authentication
  2. Set up Slack integration (optional):
    • Configure Slack OAuth for result sharing
    • Update the channel ID where results should be posted
  3. Access the form:
    • The workflow creates a web form where you can input video URLs
    • Form accepts both Instagram Reel and TikTok URLs
Requirements
  • Apify account with API access for video scraping
  • Google Cloud account with Gemini API enabled
  • Slack workspace (optional, for sharing results)
  • Videos must be publicly accessible (no private accounts)
How to customize the workflow
  • Modify the analysis prompt: Edit the "set_base_prompt" node to adjust the depth and focus of the video analysis
  • Add different platforms: Extend the switch node to handle other video platforms
  • Integrate with other tools: Replace Slack with email, Discord, or other notification systems
