Generate SEO meta tags and content briefs from SERP analysis with Claude AI
Created by: Allan Vaccarizi || growthai
Allan Vaccarizi
Last update 6 months ago
Categories
Who it's for
This workflow is for SEO managers, content strategists, and digital agencies who need to produce optimised meta tags, H1s, and full content briefs at scale — one per keyword — without doing manual competitor research.
  1. The workflow is triggered manually and reads client information and SEO keyword data from two Google Sheets tabs.
  2. Items are filtered to keep only keywords that have not yet been processed (no existing H1).
  3. A batch loop iterates over each keyword and calls the Apify SERP actor via HTTP POST to retrieve competitor URLs.
  4. Organic results are split out, limited to the top 10, and each URL is scraped with Firecrawl to retrieve full page content.
  5. A JavaScript node consolidates the scraped data into structured competitor blocks (meta title, meta description, headings).
  6. A first Claude AI agent analyses the competitor data to generate optimised meta title, meta description, and H1 (structured JSON output).
  7. A second Claude AI agent uses the same context plus the generated H1 to produce a full SEO content brief.
  8. Both outputs are written back to the correct row in Google Sheets, and the loop advances to the next keyword.
How to set up
  • [ ] Duplicate the template spreadsheet: Google Sheets Template and save it to your Google Drive
  • [ ] Connect a Google Sheets OAuth2 credential and point the two read nodes to your spreadsheet (tabs: Client information and SEO)
  • [ ] Add your Apify API key and verify the actor ID in the HTTP Request node
  • [ ] Add your Firecrawl API key to the scrape node
  • [ ] Add your Anthropic API key to the Claude Sonnet model node (shared by both AI agents)
  • [ ] Configure the Update SEO Row in Sheets node to map columns correctly in your sheet
  • [ ] Review the Filter Valid SEO Items node conditions if your sheet uses different column names
Requirements
  • Google Sheets account (OAuth2)
  • Apify account with access to a SERP-scraping actor
  • Firecrawl account
  • Anthropic (Claude) API key
How to customize
  • Adjust the Take Top 10 Results node to scrape more or fewer competitor URLs per keyword.
  • Modify the JSON schema in the Parse Structured JSON Output node to add fields such as OG title or additional meta variants.
  • Swap the Claude model or rewrite the system prompts in either AI agent to match a different language, tone of voice, or content framework.
