Analyze error logs with GPT-4o and create GitHub issues plus Slack alerts
Analyze error logs with AI and auto-create GitHub issues with fix suggestions
Who is this for
DevOps engineers, SREs, and development teams who want to automate error monitoring and reduce mean time to resolution (MTTR). Ideal for teams using GitHub for issue tracking and Slack for incident response.
What this workflow does
This workflow automates the entire error management lifecycle - from log ingestion to GitHub issue creation and Slack notification - using GPT-4o-powered root cause analysis. When an application error log is received, it parses the payload, checks for duplicates against existing GitHub issues, generates a structured root cause analysis with fix suggestions, creates a formatted GitHub Issue, and routes Slack notifications by severity. A 30-minute Wait node prevents notification flooding.
How to set up
  1. Add your GitHub Personal Access Token (repo scope) credential
  2. Add your OpenAI API credential to the AI analysis node
  3. Add your Slack OAuth2 credential (chat:write scope) to all Slack nodes
  4. Configure n8n Variables: GITHUB_OWNER and GITHUB_REPO
  5. Update Slack channel names (#incident / #dev-alerts) to match your workspace
  6. Activate the workflow and copy the webhook URL for your application logger
Requirements
  • GitHub repository with Personal Access Token (repo scope)
  • OpenAI API account with GPT-4o access
  • Slack workspace with OAuth2 app installed
  • Two Slack channels: one for critical incidents, one for general dev alerts
How to customize
Adjust the duplicate detection score threshold (default 60) in the Code node. Modify the GPT-4o prompt to focus on specific error categories. The Wait node duration (30 minutes) can be tuned to match your alerting policy.
Key features
  • Scoring-based duplicate detection (no extra API calls required)
  • GPT-4o structured JSON output with graceful fallback parser
  • Severity-based Slack routing (#incident vs #dev-alerts)
  • Dynamic GitHub labels: bug, auto-generated, environment, and critical
  • n8n Variables used for GitHub owner and repo - no hardcoded values
Node List
# Node Name Type Purpose
1 Webhook for Error Logs Webhook Accepts error log payload via HTTP POST
2 Parse and Enrich Log Code Normalizes level, extracts error type, builds duplicate search keyword
3 Search GitHub Issues GitHub Fetches open issues labeled bug,auto-generated from the target repo
4 Score GitHub Issue Duplicates Code Scores each issue for similarity; flags duplicates at threshold ≥ 60
5 Check for Duplicates If Routes to skip path (true) or analysis path (false)
6 Notify Duplicate to Slack Slack Posts link to existing issue when duplicate detected
7 Respond with Duplicate Status Respond to Webhook Returns 200 OK JSON acknowledgment for duplicate path
8 OpenAI Error Analysis OpenAI GPT-4o analyzes root cause and returns structured JSON fix suggestions
9 Build GitHub Issue Body Code Parses AI JSON and builds Markdown issue body with tables and code blocks
10 Create GitHub Issue GitHub Creates GitHub issue with title, body, and dynamic labels
11 If Critical Error If Checks isCritical flag to route Slack notification channel
12 Post Critical Alert to Slack Slack Posts @here alert to #incident with full error details
13 Post Error Summary to Slack Slack Posts summary to #dev-alerts with GitHub issue link
14 Wait 30 Minutes Wait Enforces 30-minute cooldown to prevent notification flooding
Total: 14 nodes (+ 6 Sticky Notes)
Sticky Note Compliance
# Sticky Note Title Color Role
1 Main Sticky Note (Overview) Yellow Workflow overview, How it works, Setup steps, Customization
2 Receive and parse log White Covers webhook reception and log parsing
3 Check for duplicate GitHub issues White Covers GitHub search and duplicate scoring
4 Handle duplicates and notify White Covers duplicate branch (notification + webhook response)
5 Analyze error and suggest fixes White Covers AI analysis and issue creation
6 Send alerts and summarize White Covers severity check, Slack notifications, and wait
All sticky notes use H2 headings (## ) and follow n8n public guidelines.
Webhook payload schema
{ "service": "payment-api", "level": "CRITICAL", "message": "NullPointerException at PaymentProcessor.java:142", "stack_trace": "java.lang.NullPointerException...", "environment": "production", "timestamp": "2025-01-15T09:23:45Z", "trace_id": "abc-123-xyz", "endpoint": "/api/v2/payments", "http_method": "POST", "status_code": 500, "user_id": "user_98765" }
Required fields: service, level, message
Optional fields: All others - missing values are handled gracefully with fallbacks.
How duplicate detection works
Match condition Points
Service name found in issue title +40
Error type found in issue title +40
Keyword overlap (words > 4 chars) +5 per word (max +20)
Threshold: Score ≥ 60 → duplicate detected → skip issue creation, notify Slack.
Tags
ai gpt-4 openai github slack error-monitoring devops automation
