Auto-generate and post tweet threads based on Google Trends using Gemini AI
Created by: Amjid Ali || amjid
Amjid Ali
Last update a month ago
AI-Powered Twitter Automation using n8n to Check BigQuery Latest Google Trend and Publish
Who is this for?
This template is designed for:
  • Content creators
  • Tech influencers
  • Educators and marketers
    who want to automatically tweet trend-based threads using AI and stay relevant without spending time on manual research and content writing.
What problem does this workflow solve?
Creating daily engaging Twitter threads takes time and effort. This workflow:
  • Finds trending search terms in your region (via Google Trends)
  • Selects the most relevant topic using AI
  • Generates a thread of five value-packed tweets
  • Publishes them automatically on X (Twitter)
You get high-quality, niche-specific content on autopilot — ideal for boosting visibility, brand awareness, and engagement.
What this workflow does
  • ⏰ Runs on a scheduled basis (daily at your preferred hour)
  • 🌍 Uses BigQuery to fetch the top 25 trending search terms
  • 🎯 AI Agent selects one niche-relevant trend
  • ✍️ AI generates a 5-part tweet thread using Gemini or OpenAI
  • 🐦 Tweets are published to X (Twitter) in sequence
  • 🔁 Works with any niche – simply modify the AI prompt
Setup Instructions
  1. 🔧 Google Cloud Setup
    • Create a project in Google Cloud Console
    • Enable BigQuery API
    • Use the included SQL to fetch Google Trends
  2. 🐦 Twitter Developer Setup
  3. 🧠 AI Credentials
    • Add either Gemini API Key or OpenAI Key in n8n
  4. Customize
    • Modify the AI prompts to match your niche (e.g., marketing, health, finance)
    • Adjust tweet tone, call to action, hashtags, or output format
How to customize this workflow to your needs
  • 🌍 Change Google Trends region or country in the SQL query
  • 🧠 Switch to another AI model (Claude, GPT-4o, DeepSeek, etc.)
  • 📢 Replace Twitter with LinkedIn, Telegram, or Slack integration
  • 📊 Add metrics or logging for tweet performance (advanced)
🎥 Watch How It Works
Watch on YouTube
In this tutorial, I walk you through the full automation – from pulling Google Trends to posting your AI-generated tweet thread using n8n.
Example Use Cases
  • 🔍 Daily tweet series on trending tools or technologies
  • 💹 Market insights or productivity tips based on daily trends
  • 🎓 Educational content scheduled automatically
  • 🧠 Personal brand building using consistent, trend-aware posts
Dependencies
  • n8n (self-hosted or cloud)
  • Google Cloud project with BigQuery enabled
  • Twitter Developer Account (OAuth 2.0 setup)
  • AI provider (Gemini or OpenAI)
Keywords
n8n twitter automation, tweet scheduler, X automation, auto post tweets, AI tweet writer, trending topics Twitter bot, Google Trends automation, AI content workflow, tweet generator using GPT, Twitter bot with Gemini, twitter + n8n
Support & Credit
Created by Amjid Ali
🏆 Global CIO200 | Founder of Syncbricks
If this template saved you time, consider supporting:
➡️ paypal.me/pmptraining
📚 Learn more:
