Voice Creation, TTS, Sound Effects, Voicechanger & more! 🎧 Elevenlabs MCP Server
Created by: David Ashby || cfomodz
David Ashby
Last update a month ago
Categories
Need help? Want access to this workflow + many more paid workflows + live Q&A sessions with a top verified n8n creator?
Join the community
This workflow provides a complete set of tools for interacting with the ElevenLabs voice API, enabling AI-powered text-to-speech, voice management, and audio processing capabilities.
Features 🚀
Text-to-Speech Operations
  • Convert text to speech with customizable voice settings
  • Generate speech with timestamps for precise audio control
  • Stream text-to-speech in real-time
  • Stream text-to-speech with timestamps for live applications
Voice Management 🗣️
  • List all available voices
  • Get detailed information about specific voices
  • Delete custom voices
  • Edit voice properties (name and description)
  • Find similar voices based on voice ID
Audio Processing 🎧
  • Create transcripts from audio
  • Apply voice changing effects
  • Generate sound effects
  • Isolate audio components
  • Design and preview new voices
  • Save voice previews as new voices
Requirements ⚙️
  • An ElevenLabs API key
  • n8n instance with HTTP Request Tool node
  • MCP Server Trigger node for AI integration
Setup 🔧
  1. Import the workflow into your n8n instance
  2. Configure your ElevenLabs API key in the workflow settings
  3. The workflow uses AI expressions for voice IDs with a fallback value of Z9hrfEHGU3dykHntWvIY
Usage 📝
All nodes are connected to the MCP Server Trigger for AI-powered interactions
Example Use Cases 💡
  • Generate natural-sounding speech from text
  • Create and manage custom voices
  • Process and transform audio files
  • Build voice-based applications
  • Integrate ElevenLabs capabilities into existing workflows
Technical Details 🔍
  • All endpoints use proper error handling
  • Voice ID parameters use AI expressions with fallback values
  • Nodes are organized in logical groups for better workflow management
  • Includes comprehensive parameter validation
  • Supports streaming and real-time processing
Support 🤝
For issues or questions, please refer to:
